6 minutes ago, almighty_MOE said:
How often and important should you do a registry cleaning
Once every 3 years, really it makes no difference in 99% of the times, system can work fully even with those "registry leftovers" as they are tiny tiny meaningless bits of data.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/834290-registry-cleaning/#findComment-10427675
A couple of times I've had driver crashes and bad installs/uninstalls that needed a registry cleaning, You only need to do it when there is a problem, it's not really something that should be part of a routine maintenance cycle, that said I do it monthly as I change drivers a lot.
Yours faithfully
https://linustechtips.com/topic/834290-registry-cleaning/#findComment-10427700
Not very often, especially if you're on Windows 10.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/834290-registry-cleaning/#findComment-10427758
