samsung 960 evo temps
Go to solution Solved by vanished,
That seems very nice and low, zero need for worry
Even 40s or 50s would be fine.  I think you need to start paying attention if they hit 60+
Hi everyone!
I was wondering what normal temps of the samsung 960 evo is (512GB) is. Mine 34C (93F) degrees while gaming and 28C (82.4) idle. I can't find a normal site/page from samsung where I can see the max temps like intel does. Can someone help me?
Thanks!!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/833636-samsung-960-evo-temps/
https://linustechtips.com/topic/833636-samsung-960-evo-temps/#findComment-10420898
Thanks! I was a little worried because I read that the msi Z270 (pro gaming carbon) m.2 shield increased temps by most people. I didn't know what were normal temps for m.2 but I'm glad evertying is fine :)
https://linustechtips.com/topic/833636-samsung-960-evo-temps/#findComment-10420921
My 250GB version is running at 40 degrees C at the moment and that is with quite some programs open.
https://linustechtips.com/topic/833636-samsung-960-evo-temps/#findComment-10420962
