If it's just a ground pin it shouldn't affect anything but that's a crap shoot since we'd need a schematic to verify that. You're better off repairing it if you can.
https://linustechtips.com/topic/833618-bent-pin/#findComment-10420552
2 minutes ago, TheRapidGamer said:
Can i rma if its still under warranty this happened while i was trying to install thier cover.
You can try.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/833618-bent-pin/#findComment-10420579
11 minutes ago, TheRapidGamer said:
Welp RIP Ga-Z170-Hd3p. Good thing u cant bend pins on x370 xD
Of course you can, it's usually even worse since they are on your cpu :D
Shops and manufacturers usually don't rma for bent pins since you damaged it. They might even charge you to repair it.
https://linustechtips.com/topic/833618-bent-pin/#findComment-10420664
Im just not gonna bother then xD. Still you are usually more carefull while handling a cpu than a mobo.
https://linustechtips.com/topic/833618-bent-pin/#findComment-10420773
You can always try, they might help you out. If not, it's usually not that hard to fix yourself if you're being careful. Yours is right on the edge so even easier to reach, worth a try if you've nothing to lose.
I've seen cpu's where they were forced into the socket and crushed all the pins. As long as you don't force or drop the cpu, you should be good (pga cpu pins are thicker, sturdier than lga mobo pins).
https://linustechtips.com/topic/833618-bent-pin/#findComment-10421008
Theres a god chance this wont be covered as it will be classed as 'User damage' (or Something like that) - DW this happened to me and if your steady its easy to bend it back
https://linustechtips.com/topic/833618-bent-pin/#findComment-10421214
