https://pcpartpicker.com/list/fFNcwV
I'm planning this as a light gaming rig (for esports such as Overwatch, League, and Hearthstone) that I can take to LAN parties and transport relatively easily from my home in Virginia to school in Utah. I already have a Windows key from my main build (in my signature), and I've already got a monitor at both locations. I was debating between the 460 and the 1050, but I went with the 460 for the extra 2 gb of VRAM. I haven't been able to find a 560 in the graphics card price point I'm looking at ($120). Additionally, I wasn't sure which CPU to go with, so I could use some advice there. I'd like to keep the CPU under $100 if possible. Aaaand I'm also not sure about the PSU. Basically this entire build is up in the air, and comments and advice are appreciated. Thanks!
PS: Yes, I do need wifi.
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/832377-mini-itx-build/
Get a h110 board instead, otherwise, looks good. This one for example.
https://pcpartpicker.com/product/x2mxFT/asrock-motherboard-h110mitxac
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408001
I may be completely off my rocker, but don't H110 mobos need a BIOS update before they can use G4600s?
Current Desktop:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408013
those you can buy new now comes with new BIOS from the factory
Desktop benching:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408046
PCPartPicker part list: https://pcpartpicker.com/list/tMhkYr
Price breakdown by merchant: https://pcpartpicker.com/list/tMhkYr/by_merchant/
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($78.89 @ B&H)
Motherboard: ASRock - H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($68.99 @ Amazon)
Memory: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2133 Memory  ($45.99 @ Amazon)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  ($144.98 @ Newegg)
Case: Cooler Master - Elite 110 Mini ITX Tower Case  ($32.98 @ Newegg)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $515.81
Generated by PCPartPicker 2017-09-08 11:10 EDT-0400
G4560 is a few dollars cheaper with next to no performance difference to the G4600.
Cheaper mobo with WiFi
Cheap 8GB RAM set
Same SSD as the one you picked
1050ti for more firepower (dont buy cheap cards with high VRAM in the first place. Not worth the extra price)
This PSU is fully modular, has higher capacity and slightly lower price
Desktop benching:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408087
not in stock.
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408196
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($62.98 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  ($144.99 @ Amazon)
Case: Silverstone - Sugo SG13B Mini ITX Tower Case  ($39.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($37.99 @ Amazon)
Total: $523.82
Generated by PCPartPicker 2017-09-08 11:41 EDT-0400
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408213
Not ones that come with the newer bios outta the factory. Considering it's over 9 months since Kaby Lake launched you're extremely unlikely to see one new without a newer bios.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408214
Total: $523.82
Looks good. I may swap the PSU for a modular one, to aid with cable management (I like my builds to look clean) but otherwise I like these choices.
Current Desktop:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408224
if you're fine with rebates this looks pretty good but you'll have to pay up $60 first.
 https://www.newegg.com/Product/Product.aspx?Item=N82E16817139059&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408240
12 minutes ago, herman mcpootis said:
not in stock.
ok fixed. thx for the reminder
PCPartPicker part list: https://pcpartpicker.com/list/Bg2m9W
Price breakdown by merchant: https://pcpartpicker.com/list/Bg2m9W/by_merchant/
Total: $532.80
Generated by PCPartPicker 2017-09-08 11:52 EDT-0400
Desktop benching:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408256
3 minutes ago, herman mcpootis said:
OMG not a green label Corsair PSU
Desktop benching:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408263
looks like you've just confirmed my suspicions. no, just because it has a green label from corsair does not mean it is bad. tier 3 in the list.
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408292
tier 3 are grey label ones. Look at tier 4. It specifically mentions "green unit"
Desktop benching:
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408320
CS, not CX.
https://linustechtips.com/topic/832377-mini-itx-build/#findComment-10408333
