Do I really need a drive cage/drive sled for 2nd 2.5" SSD?
Solved by Oshino Shinobu,
Just now, AluminiumTech said:Would taping it down with Electrical tape be fine?
I might try to tape it down to a side of the case if it's fine.
Yep, that's fine. I edited my post to explain a bit more.
SSDs don't need to be secured like HDDs as they don't have any moving parts, so they don't need to stay still and aren't affected by vibrations, shock or movement. If you have some double sided tape, I'd use that, but just some tape over the SSD to stick it down will work fine.
