Probably the second one, the ryzen 3 will bottleneck the gtx 1060. Take care!
  • CPU
    Ryzen 5 1600 OC 3,7ghz
  • Motherboard
    ASrock AB350 Pro4 ATX
  • RAM
    A-Data 2666mhz upgraded to Corsair LPX 2x8gb 3000mhz
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
    1TB HDD, 240gb M.2 Intel NVMe SSD
  • PSU
    Evga 600w B+
  • Display(s)
    Samsung Full HD 24' Free sync
  • Cooling
    3x 120mm case fans
  • Keyboard
    Razer BlackWidow Chroma V2
  • Mouse
    Razer DeathAdder Elite
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
2 minutes ago, PyotrK said:
Gaming (aiming for 60 fps, any settings)
and school
the second one. pentium and 1060 should not bottleneck much
but g4560 is bit slower than rtzen 3
1 minute ago, PyotrK said:
ahh crap messed it up its supposed to be ryzen with 1050 ti and pentium with 1060 3gb
Still, anything below Ryzen 5 1500 will bottleneck the gtx 1060, so get the g4560 and gtx 1050 ti. Should be good at medium settings.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
It is a bit slower but only if you overclock that ryzen 3, if not they are 5 fps apart. AT MOST.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
Just now, PyotrK said:
I understand, but i can upgrade the ryzen, but not the g4560
It's true the ryzen has a better upgrade path
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
That is such a loaded statement. People saying that a cpu will bottleneck a gpu without clarify what game, resolution, or settings either don't know enough about bottlenecking to give proper advice or are plain misleading. From all testing done on both the Pentium g4560  and the r3 1200 it is clear that games scale well up to the gtx 1060 so although you may have a slight bottleneck depending on the use case, it isn't bad enough to warrant limiting yourself to a gtx 1050ti.
just
Just now, staubgame said:
Jay did a video on this just today. :D
There ya go
(He also tries ryzen 3)
And for Intel you can go up allthe way to an i7-7700 (locked works fine as well ;) )
just watched that, and that is why i asked this question :D
