I am about to overclock my GT740m x128bit 2GB DRR3. It never really overheats while gaming, only the CPU does, so I think overclocking won't roast it, but any advice on how many MHz I should add to the Clock? Should I also increase the memory clock or only the Core Clock? I was thinking of boosting it by 100MHz (From 810 to 910MHz). I also just cleaned the fan and added an external cooling pad.
https://linustechtips.com/topic/831948-overclocking-for-gt740m/
1. Make sure you can do it. Some laptops have locked it fully so you cant overclock it.
2. Laptop chips can only go 135MHz on the core (if I recall correctly), which is far from its limit. Push it all the way up.
3. How high the memory would hold depends on the quality of chips you get. Start from 50MHz first and add 10Mhz for each successful stability run.
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403388
First of all, what's the temps for CPU and GPU in load tests?
Second, some laptop have shared cooling design which means CPU and GPU are cooled together in 1 or more heat pipe. The temperature increase from the GPU will affect the CPU temp too
Also, external cooling pad doesn't help much, undervolting does.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403402
Did as you said. Will not restart and check if it runs games better.
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403497
so it black screens? Reset the memory overclock then.
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403502
Will now restart* , the Laptop still works. Max GPU temp is 86c, I ran Saints Row: The Third to see if there were any improvements in the Framerate an it looks like it's running just like before OC (Average 24 FPS Maxed Out Direct X 11-12) only setting that I changed is Shadow Resolution (From LOW to HIGH) and FPS is the same as when it was set on LOW so, I presume the Overclocking worked? Not really sure.
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403539
Could you identify if the CPU is the one holding it back?
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403617
7 minutes ago, DarkMesa said:
I have an i3 1.8GHz as CPU, bottleneck?
idk. How is the usage and clock speed for CPU and GPU?
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403662
39 minutes ago, DarkMesa said:
Max. 60% so no bottleneck.  Played some Battlefield 4 and haven't seen any gain in performance.
60% on GPU? then how about the CPU? 1.8GHz dual core is weak, but I'm not sure if it will bottleneck a 740m which is also weak.
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403774
60% is CPU usage, not GPU usage. Sorry, I should have been more specific.
Tehn maybe push the memory clock a bit more? using the slow DDR3 as VRAM,  this should give some extra fps. Otherwise it could just be too weak to give noticeable difference with overclocking (too bad nvidia locked the core clock offset that low).
Desktop benching:
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10403796
Used GPU-Z and yes, memory clock is now 900+ MHz Instead of the base 810. I don't see a single FPS improvement in performance, should I blame my CPU for that?
https://linustechtips.com/topic/831948-overclocking-for-gt740m/#findComment-10405156
