Thermaltake PSU PCI-e help.
Go to solution Solved by GOTSpectrum,
6 hours ago, ERanck said:
in my build I plan on putting in an ROG STRIX 1080, but the PCI-e cords that came with my PSU are ugly. I was planing on just using one of my friends PCI-e cords but we realized that the way the pins were shaped made it so it could not fit in my PSU. I think that the PCI-e cord was from his EVGA PSU. I wanted to know if i ordered a PCI-e cord from cable mods, would I be able to make it so that it fits my PSU?
Don't try to use cables from different PSUs! You can either buy extension cables, sleeve them yourself or find someone who sells modded cabling, BUT you need to make sure it matches your PSU.
https://linustechtips.com/topic/830626-thermaltake-psu-pci-e-help/
This would be VERY tedious because I've done it to my own PSU but you could sleeve the power supply cables yourself with any array of colors. You would need 1/16th inch sleeving and a pin remover.
...and a lot of time, patience, and the ability to deal with rubbing the flesh off your fingers to the point where it's a dull pain to touch anything...don't sleeve your entire PSU to avoid the 3rd condition. Also to avoid RTS in your hands/wrists.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
9 hours ago, deXxterlab97 said:
Which Thermaltake?
https://www.newegg.com/Product/Product.aspx?item=N82E16817153310
Thank You! this helps a lot.
