I was getting 125 MB/s speeds (1000Mb) on my NAS to desktop. I moved it now I only get 11 MB/s (100 Mb/s).
I suspicion It may be the ethernet cable. It's about 50ft long and run through ceiling tiles and a floor.
How do you properly test the cable? (I dont want to run another unless I have to).
https://linustechtips.com/topic/829813-1000-not-100-speed/
You moved it? Are all the connections still intact? Have you tried unplugging and plugging it back in? Is there an intermediary device such as a switch in between?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/829813-1000-not-100-speed/#findComment-10382084
Is it a particularly old cable? You can rule out cable fault if you can try a different cable or if you can plug a different computer into the existing cable and see if it's Gigabit or not.
Also, check the network adapter configuration. Does it say 1000 or 100? If there's a power cable running along side the Ethernet cable the magnetic field can corrupt the signals in the wires and cause mass packet loss. Because it uses the TCP protocol your file(s) will still transfer successfully but at the cost of drastically reduced speed.
https://linustechtips.com/topic/829813-1000-not-100-speed/#findComment-10382528
