So my stock amd cooler is really loud!! I am looking for a quiet cooler that performs well. I know the hyper 212 evo will be the first thing everyone will say but I want some alternatives. I am willing to spend around 35-50€. My cpu is an FX 8320 at stock but I am willing to do some overclocking maybe at 4.0GHz no more.
Thanks
AMD FX 8320@ Stock - Asus M5A99X Evo R2.0 - Kingston HyperX 8GB 1600Mhz - Corsair Carbide 200R - Powercolor Radeon HD 7950 PCS+OC@970Mhz core 1400Mhz memory - Corsair CS650W - Samsung 840 EVO 250GB
LG 22EA53VQ 21.5" - CM Storm Xornet - CM Storm Quickfire TK - Creative Inspire T3130 2.1
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/
be quiet! Dark Rock?
Otherwise, even though you dont want it....the 212 is unbeatable at its price range.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/#findComment-1129518
If you don't want a hyper 212 you can go with something like... an h60?
The H60 costs like 70€ here.
 I though about it too but I can only orient it like this
thermalright true spirit 120 or 140 if it fits in the case. very good cooler
also thermalright HR-02 macho
if you want to go crazy buy the thermalright silver arrow SB-E
The true spirit doent look good but the HR-02 does, searching for it right now. The arrow is out of my budget.
Its not that I dont want the hyper 212, Its a great cooler but I just wanted to see what alternatives there are
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/#findComment-1129551
Just found the Enermax ETS-T40. Is it any good? I heard that the enermax fans are super quiet.
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/#findComment-1129568
Alpenföhn Brocken 2, if that is a thing in greece.
Found it for 40€! Checking for reviews now
Edited by Andrew48
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/#findComment-1129579
The Hyper TX3? :D I don't know. All I know is when you modify it to work with socket 478, take a picture before your damn bracket breaks.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/82791-need-a-new-cpu-cooler/#findComment-1131182
