I recently upgraded to an AMD Ryzen 7 1700 cpu. I am running this on an Asus ROG Strix b350-f Gaming mobo with an AMD Asus Strix RX 480 8GB. After installation I have been stuck with issue after issue. I cannot get my games to run correctly, and sometimes one game will run fine and the other just keeps crashing. I don't know whats going on. I've unplugged and plugged back in all my cables, reinstalled all drivers and windows a couple times now, and everything is up to date. I have no idea what to do and neither does my friend who is big into computers as well. There's no hardware failures detected and I'm running stock speeds on my CPU with my RAM (2 x 4GB Corsair Vengeance LPX) having been both overclocked and at stock speeds. Also, Radeon settings is saying I have a freesync monitor when I know I do not. If anyone has any ideas please help because I am at a total loss. Also, this is one of the errors I get when I try to play Deus Ex: Mankind Divided. (I apologize for the picture taken with my phone)
https://linustechtips.com/topic/827769-ryzen-not-working/
I got this error while playing Rise of the tomb raider when my GTX 1070 was overclocked, but not when it was at stock speeds (just an overclock pushed too hard)
maybe your RX 480 just barely got past the binning process, and can barely run at stock speeds?
try giving it more power limit and voltage without adjusting the core clock, and see if that fixes it
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/827769-ryzen-not-working/#findComment-10361545
I don't see why this would be an issue. Stock it runs at 1310MHz at 1.15V. I had it previously overclocked to 1380MHz at 1.20V and it ran stable like that for several months. It is currently not overclocked at all because I've been reinstalling Windows 10. I will try this though.
https://linustechtips.com/topic/827769-ryzen-not-working/#findComment-10361554
what about CPU and RAM? is that OC too?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/827769-ryzen-not-working/#findComment-10361567
1 hour ago, CPU_bot said:
CPU is running at stock speeds and voltages. Ram has been set to both stock speeds and voltages as well as the D.O.C.P profile that makes it run at 2933MHz at 1.35V
You should be fine as long as you dont OC your CPU. I think the issue may be caused by bad driver installation. Reinstall Crimson drivers and try it.
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/827769-ryzen-not-working/#findComment-10361853
