Pc losing power
AA04
I just finished my new PC (https://pcpartpicker.com/list/GbqkNN)
It boots fine and starts up all my programs but as soon as I try to launch something else it instantly shuts down (all fans and lights turn off)
I thought this was an issue of not having enough power so I upgraded from 450w to 750 and nothing changed. I know all my parts work fine except for the graphics card as I just got it used, but it seems like a graphics issue shouldn't shut down the whole PC. Any suggestions?
After more investigation, I can browse the web fine and stream video, it's just as soon as I open a game or a benchmark that it turns off
thats a green corsair PSU, return it, its a potato with wires
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Do you have another GPU to test with
Is there a blue screen?
My life
My 950 worked fine with the same parts except a weaker power supply, no blue screen just straight power loss
Is this the problem, or is that just an offshoot suggestion?
yes
green corsair PSUs are potatoes with wires, grey ones are much MUCH better.
this is a green unit
Image result for corsair psu grey
this is a grey unit
1 minute ago, themctipers said:
yes
this is a grey unit
So if I got a grey you think the system would work?
yes
