Hello everyone Im a long term lurker here, first time poster...
Not sure if anyone else is having issues with windows 7 throwing a BSOD when a usb device is plugged in, did a quick search and didnt find anything.
This happens about 50% of the time for me and only on the front panel connection. I have the newest BIOS and windows updates.
Any insight as to what is causing this? Fault front IO connector? Faulty MB?
Relative Specs:
Maximus VI Hero w/ 4770K
16Gb Vengeance-1600
Samsung 840 Pro
Fractal Define R4
Windows 7 64bit
CPU: i7 4770k @ 4.3Ghz with NH-D14 | RAM: 16GB Corsair Vengeance 1600MHz | Motherboard: ASUS Maximus VI Hero | GPU: SLI GTX780 Windforce | SSD: Samsung 840 Pro | HDD: WD Black | PSUEVGA SuperNova 1300W | Case: Fractal Define R4 | Monitor: X-Star DP2710 1440p @ 96Hz | Mouse: DeathAdder  | Keyboard: CM Storm CherryMX Red | Headset: Kraken Pro | Headphones: HE-400
https://linustechtips.com/topic/82633-bsod-from-usb-devices/
Could be an issue with the usb driver on your motherboard. Have you tried reinstalling it? Or the front panel can be the issue, i have mine hard shutdown my computer by putting in a usb drive.
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
https://linustechtips.com/topic/82633-bsod-from-usb-devices/#findComment-1127845
does this happen when you plug into both usb2 and usb3 port?
Its never happened on the USB2 port, only USB3.
@MeltyMoon Windows says the USB3.0 Root hub driver is up to date (2.5.0.19)
When I put my rig together I remember the entire front assembly accidentally came off, disconnecting the power/reset buttons - wonder if that messed the USB connection too...
https://linustechtips.com/topic/82633-bsod-from-usb-devices/#findComment-1128040
