1 minute ago, JackDoyne said:
Probably poor airflow, however unless people have the exact same fans and case as you it's hard to tell, although that temperature seems pretty normal and won't cause you any issues
well its only on gta V on battlefield 4 i have 73ºC max
https://linustechtips.com/topic/825914-strix-1070-oc-temps/#findComment-10340810
Are the fans installed in the right direction so intakes suck air and exhausts push air out? Strix cards have good cooling so 83C (also known as Nvidia's temperature limit) is quite high.
Desktop benching:
https://linustechtips.com/topic/825914-strix-1070-oc-temps/#findComment-10340853
