i have a micro atx msi h81m-e33 mother board (pictured below)
i want to get the DeepCool CPU Cooler FROSTWIN V2.0 as it is on sale on amazon
i think it will fit fine but i dont want it to be to large and intersect the side of my case
anyone have any insight?
thank you
https://www.amazon.com/dp/B00RZ8DM9Q/ref=psdc_11036281_t5_B00OLA0BOA?th=1
https://www.amazon.com/MSI-Intel-Micro-Motherboard-H81M-E33/dp/B00F42W70A/ref=sr_1_1?s=electronics&ie=UTF8&qid=1503381907&sr=1-1&keywords=msi+h81m-e33
Image result for msi h81m-e33
Image result for DeepCool CPU Cooler FROSTWIN V2.0
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/825359-cpu-cooler/
I think I would get something else
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335077
can you provide any insight?
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335082
If you mean the Elite 130 in your sig, the case only has a 65mm of clearance for the cpu cooler which isn't enough for the 150mm tall Frostwin 2.0
Why are you looking for a new cooler?
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335088
i have one of those, i can measure out how large it is
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335091
CRYORIG H7 or 212X Dual
https://pcpartpicker.com/product/93Crxr/cryorig-cpu-cooler-h7
https://pcpartpicker.com/product/KzfmP6/cooler-master-cpu-cooler-rr212x20pma1
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335098
thank you very much. also how do you like it? is it a good cooler? also pls measure from the edge of the socket to the edge of the heatsink
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335102
Hm, Cryorig C7 or Noctua NH-L9i are very capable low form-factor coolers.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335104
Just now, JDE said:
while there may be better options i dont really need this product. i have a locked cpu. i just want slightly better cooling and im a sucker for a good deal so this 50% off makes the VALUE compelling. if there wasnt a sale i wouldnt be buying in general
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335107
May I redirect you to what I think you are trying to respond to
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335108
oh well go for it then
stock cooler will be just as good though
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335109
i got a new case today and forgot to upgrade my sig LOL. i got a mastercase 3.1 lite so vertical clearance is less of an issue
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335112
xD
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335114
i like it, $35, replaced my 212x and it is slightly better than a 212x
if you have anything near a 212 evo and are paying >$30 or so for one, not worth.
don't think measuring is a thing i can do, but here is a picture.
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335115
Oops, I went and got a drink thinking the other thread had loaded. My bad!
My PC:
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335119
that picture is a huge help thank you very much :) looks like im buying it afterall
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335121
The Frostwin 2.0 isn't that much better than similarly priced coolers if you want something quieter. A PR Slim would do a better job of that: https://pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335124
frostwin is terrible for being quiet in idle. i have it plugged into a case fan header to keep it from going VRRRR in idle and 5% load
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335130
i would go with the bequiet if i wasnt leaving for college in a few days. unfortunately it is more expensive on amazon and i have prime so ill have the other one sooner. thank you for the suggestion though :)
https://linustechtips.com/topic/825359-cpu-cooler/#findComment-10335131
