My family has this problem where when I decide to play games, they experience lag and slow connection. Even I experience problems while I'm using my phone at the computer. Is there a way to fix this? Is it because I'm using Ethernet? Is it because my plan or Charter sucks?
Sorry if this is a simple problem, not very experienced with internet and all that
On the side note, what does killer Ethernet do?
https://linustechtips.com/topic/825322-how-do-i-not-be-an-e-hog/
What's your speed? Do a speedtest at speedtest.net
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
It's likely your AP. If it only has one band, you'll only be able to serve one person at a time meaning a request will need to be processed before moving to the next request.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
check your speed first though
Full Specs
Helios EVO (Main):
Delta - Laptop
Yes its because you don't have enough bandwidth to support all your devices.
Killer Ethernet is just a brand of controller targeted at gamers. Generally Ethernet is all the same unless you are getting into enterprise solutions. Don't be swayed by things like "10GB ethernet!" "dual Ethernet ports!" "Killer or Gaming Ethernet!" Its all blab and marketing that has no real use unless you are doing something other then gaming and/or know a good amount about networking.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
There are a few things that could be occuring, i'll list them in order of likelihood
  • you don't have enough bandwidth to support a lot of stuff at once, so when you're gaming, there just isn't enough left to service everyone else
  • your router cannot handle many users' concurrent requests, so it becomes slow with many users at once
  • you have QoS (Quality of Service) enabled on your router for your PC, so its traffic gets prioritized over others. This is unlikely since that's something that would have to be consciously done, normally.
    • That being said, some routers will normally prioritize wired (ethernet) traffic anyways, so that could be related.
  • Your family is trying to access the same ports as you (ports are kinda like lanes on a road) when you game, so you have to wait or each other's traffic to clear before the next user can do so. but this is VERY unlikely.
As for the question about killer ethernet, they are simply a company that makes ethernet jacks/drivers. Intel is another company that does. Killer often markets to gamers by claiming that they will prioritize packets from your PC that are gaming-related over others from background processes, etc. Most ppl agree it doesn't really help, and some claim worse performance than Intel NICs and such. I wouldn't really pay much attention to it.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
Er, what's an AP exactly? I understand it's an access point...So is that my router or...?
I've done multiple, and it's usually 11-16 ping with 60 down 5 up
what are you running in terms of a router?
RAINBOWS!!!
It's whatever is giving your family wireless access to the internet. Do you know what AP you're using? Is it single-, dual-, or tri-band? Is it using b/g/n/ac 803.11?
10 minutes ago, xZeroOnyx said:
It's an Asus dual-band 802.11ac specifically the Asus RT-AC52U
I think it is just that you have too many people on the network at the same time. It COULD also be that they are eating up your 5MB upload and having the download not hit as hard. I'd say go into the settings and set up a bandwidth cap for each Ethernet port and WiFi connection. Since it is a relatively high end device it should be possible. Also you should be able to get it to prioritize Ethernet connections over wireless.
RAINBOWS!!!
yep you can!
RAINBOWS!!!
I think it's the access point that's slowing you down.
Full Specs
Helios EVO (Main):
Delta - Laptop
