Help
FoxAxe
so my case define s window
does not have a optical drive place and i propaply not going to need it but my old pc has a dvd reader and if i happen to need it i just wanted to know if i can ghetto mount it into my pc for like short perioids
If it's only for short periods, I would look into a
nevermind.. ninja'd
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
That's what I use by the way, for when I need to rip/burn blu-rays etc.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
7 minutes ago, Lurick said:
You can get an external USB enclosure for 5.25" DVD drives or something
btw my mobo comes with only 4 sata cables and im going to need 6 my old pc has like 4 satas can i reuse them are they dangerous to the new pc or....
10 minutes ago, FoxAxe said:
@Lurick
Due to AMD Ryzen™ Processor limitation, More than DDR4-2666 is supported by one DIMM per channel only
what does that mean i found it in my mobos spesification
https://www.asus.com/Motherboards/ROG-STRIX-B350-F-GAMING/specifications/?
Yoy can pretty much ignore that, the relevant info is this
AMD Ryzen™ Processors
4 x DIMM, Max. 64GB, DDR4 3200(O.C.)/2933(O.C.)/2666/2400/2133 MHz ECC and non-ECC, Un-buffered Memory *
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Yah. Though Ryzen doesn't like high speeds on more than 2 sticks, so 2x8GB or 16GB is the best bet.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
yay i got just that 16gb of 3000mhz ram
corsair Vengance
Well yeah, basically it's saying that ryzen is only dual channel, and that speeds above 2666 isn't supported for more than one dimm per channel. So 2 sticks = speed above 2666, 4 sticks won't go above 2666.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
corsair Vengance
Nice. 2x8? And Corsair Vengeance is good RAM.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
yeah 2x8
