Help
Andrew8499
I just bought my pc and I have civ 5, stellaris, hearts of iron, team fortress 2, minecraft. Got any ideas on what else I should buy, or wanna play any
The Total War Series is the marriage between Civ and Hearts of Iron.I would look at Shogun 2.
My life
Thank you so much
overwatch
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
  • 2 weeks later...
I will put a long list of great games. I recommend you play these over a long period of time. there are a lot of games here, and i have yet to finish many on this list.
If any game you feel it's missing, it means i either haven't played it (as of now), or simply do not enjoy it/ think it's worth putting in the list.
Note: Since the list is big, and my genre organization probably isn't that good, you might want to look at some footage before trying it out each game. And some games are old, but I play games for how the game is, and not for graphics. hope you don't mind.
Have Fun!
Best Games PC.txt
Forgot to add Civ 4.
