I dont know a ton about XMP, other than I have it and it boosted my RAM from 2133 to 2400.  And that its supposedly optimal settings for memory overclock.  But my mobo, Asus Prime z270 has more headroom that I'd like to experiment.  If I play with the memory speeds, do I also have to adjust voltage and timings?  Or should I just trust that XMP is the way to go.
System:
Asus Prime AR z270
i5 7600k
16GB DDR4 2133 (2400 xmp)
M.2 + HDD
RX480
https://linustechtips.com/topic/824234-xmp-vs-manual-overclock/
XMP = Poor man's OC, it works and it's better than stock.
Manual = Takes your life away, but can be much faster once you tighten the timings and bandwidth to their limits.
@MageTank has a RAM overclocking guide if you're interested, but be warned that it's a lot of text to understand.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/824234-xmp-vs-manual-overclock/#findComment-10322775
a manual overclock should give you better performance, probably higher frequency and lower/same timings or just much better timings. its a pain to stress test it but its fun to do if you want to push up that Cinebench score by another few points
Builds:
https://linustechtips.com/topic/824234-xmp-vs-manual-overclock/#findComment-10322796
XMP is just the manufacturer's guaranteed RAM settings memory wise (i.e it might still not work because of other hardware disliking the configuration).
This means you might be able to squeeze out some extra juice out of the RAM sticks over XMP by manually overclocking it.
I usually just manually input the XMP settings, check if the system likes it, and then take it from there and do further overclocking and tweaking.
Though as stated above, one should only dive into memory overclocking if you really enjoy overclocking as one can argue wether or not the small performance increase is really worth the effort and time (at least at those low speeds).
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/824234-xmp-vs-manual-overclock/#findComment-10322888
