5 minutes ago, Mikailk said:
I plan on getting the HP Spectre x360 13.3". I plan on getting the 4k one. Would reducing the resolution to something a little higher than 1080p improve battery significantly?
Yes. 13.3" for 4K is stupid on Windows which can't scale properly for that.
4K at 13.3" is basically a giant "f*ck you" to customers. You won't be able to see it, your GPU performance will be shit, and your battery life will be shit.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
well Windows has scaling for the environment. 100% scaling is ridiculous, but it's still 4k. Would reducing it to 1440p or something like that considerably save battery?
If you mean getting the 4K screen and turning down the resolution in Windows, it will improve the battery life by reducing GPU load a little, but it's not as significant as getting a lower resolution screen. Most of the power for the screen is for the backlight, and higher pixel densities require brighter backlight (more power) to achieve the same level of brightness as a lower density screen. Lowering the resolution in Windows won't change the physical resolution or density of the screen.
So what you're saying is it's almost pointless downscale the resolution. I have 30 days with the laptop. When I have it i'll benchmark it with scaling and without. The 1080p version just seems like a not great option considering most high-end laptops are at about 1440p these days.
