Hey,
I just recently upgraded from a 960 to a 1080 and have been thinking that my cpu is bottlenecking my gpu as on games such as csgo i have seen about 30fps increase but in pubg i have seen 80fps improvements. I ran a cinebench test for my gpu (got a score of 103fps) and was wondering the following things:
  1. If the cpu affects the gpu banchmark;
  2. If not, why the score is low  compared to other 1080 cards.
I was thinking if i should get a i7-7700k or wait for coffee lake. Just need some advice :)
Thanks.
CPU: i5-4690
https://linustechtips.com/topic/822332-low-benchmark-fps/
What CPU are you running?
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/822332-low-benchmark-fps/#findComment-10303420
1 minute ago, Dobbie said:
i5-4960 sorry
No such thing as that?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/822332-low-benchmark-fps/#findComment-10303436
4 minutes ago, Dobbie said:
Hey,
Thanks.
CPU: i5-4960
The cinebench GPU test isn't a very good metric. The CPU is pretty much the factor for the GPU test. Fast single thread with your 1080 would give a good result. Slow i5 and 1080 = not very fast.
Use Superposition or 3DMark bench tools.
https://linustechtips.com/topic/822332-low-benchmark-fps/#findComment-10303449
Just now, Rupe said:
I think its safe to assume he meant the i5 4690
Yep and the i5 bottle necks the 1080 so just wait to upgrade
https://linustechtips.com/topic/822332-low-benchmark-fps/#findComment-10303452
Just now, Dobbie said:
It was clairrifed nowI know which CPU you have
https://linustechtips.com/topic/822332-low-benchmark-fps/#findComment-10303458
