It might just be something as simple as the monitor not being set to the correct input (if your monitor has multiple types of input)
Should be a button on it to switch between them.
Otherwise try hooking up another monitor if you have one and see if that works.
https://linustechtips.com/topic/822245-no-signal-detected/#findComment-10302688
