Hi guys,
so i was scrolling though workstation builds and i stumbled apon something called a ups. Now the basic idea (i think) is its a battery to keep your pc running when there's no power. I'm wondering if anyone could help choose one, so ive got a pc,
-i7 6700
-asus 1070
and a nas
-500w max ever
and a wifi router.
i want to be able to keep using my pc all the way though the power outage so I'm wondering if anyone can recommend one.
thanks,
BDunkz
https://linustechtips.com/topic/820712-a-ups/
Just buy this one and you are golden
Tag me if you need me :D
Desktop:                                       Laptop:
CPU - i7-4790k                            CPU: I7 7700HQ
GPU - Inno3D 1080TI                  GPU: 1060
Mobo - Gigabyte Z97X-SLI          Memory: 16 GB
Memory - 32 GB DDR3                Storage: 1256GB
Storage - 11 TB
Phone: ONEPLUS 6 128GB
https://linustechtips.com/topic/820712-a-ups/#findComment-10285881
How long of a power outage?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/820712-a-ups/#findComment-10285884
That's not what a UPS is for. It's for saving your content and shutting down properly. usually 5 or 10 mins battery time
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/820712-a-ups/#findComment-10285885
yep thats the only way you can last a power outage
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/820712-a-ups/#findComment-10285887
its more suited towards having enough power saved up so that you can stop what you're doing and shut down the computer safely instead of it just suddenly shutting down. you won't be doing any gaming while the power is out on your desktop
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/820712-a-ups/#findComment-10285888
Most UPS are not designed to be used "through a power outage". Most consumer units are designed to give you enough time to gracefully shut down your system (so, maybe 10 minutes).
Otherwise, your best bet will be something from APC or Cyberpower. I'd reccomend at least 1000VA, preferrably their largest consumer ones, which are (I think) 1500va. https://www.amazon.com/APC-Back-UPS-Battery-Protector-BR1500G/dp/B003Y24DEU
This will give you ~20 minutes, maybe, to shut down your systems. Once your systems are shut down, it could probably run your networking for a couple hours as well.
The other thing to think about, is auto shutdown. Each of these can control one system via USB cable, to tell the system to shut down.
So, you may need to get two.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/820712-a-ups/#findComment-10285902
4 minutes ago, BDunkz said:
-SNIP-
As said they are more designed for saving critical work and safely shutting down your system, there are units that are designed for extended run time but cost a lot of money. Something like this would be more than enough for your system, ideally for the NAS that should be on it's own unit for it to be able to safely pwoer down during an extended power outage.
https://www.cyberpowersystems.com/product/ups/cp850pfclcd/
-Moved to case and power supplies-
https://linustechtips.com/topic/820712-a-ups/#findComment-10285903
Generally speaking, a UPS is used for two reasons:
  • Smooth out power delivery to the system, protecting sensitive components from fluctuations/ surges
  • Safely saving your info and shutting down your system in the event of a power outage - tops 5-10 minutes of use
A good brand name ups like APC will run you about $200-250 USD and you'll need something like this:
PC Power-Saving Back-UPS Pro 1300
https://linustechtips.com/topic/820712-a-ups/#findComment-10285913
Just now, BDunkz said:
5-20 mins
maybe 10-15 mins, probably not 20
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/820712-a-ups/#findComment-10286606
OK well if it was just For Saving some stuff and shutting down the nas, how much would I have to spend?
https://linustechtips.com/topic/820712-a-ups/#findComment-10286612
