FPS drops / Stuttering across all games and cards - help
That's your problem, you tried uninstalling just using the OS. When you "uninstall" a driver through the OS it doesn't actually uninstall. You need to download the program Display Driver Uninstaller (DDU) to your system. Once you get that installed and setup to where you can find it easily you need to restart your PC and boot into safe mode. While in safe mode launch DDU and uninstall your drivers then restart your system again. I would suggest doing this while on integrated graphics just to make sure it get's any traces of Nvidia off your system. Then once you've uninstalled all Nvidia related things you can put your 1060 in and download the drivers straight from Nvidia. I wouldn't even suggest using GeForce Experience as it kind of sucks now.... a lot....
But the reason you are having this stutter problem is because without DDU windows does not uninstall the driver completely, so when you "uninstalled" it it just deleted a few of the files but didn't get rid of it completely. So when you reinstalled it just put the new driver on top of the old driver and your system was trying to use both at once which is what made everything go wonky.
TL:DR, Download DDU, Install DDU, reboot system into safe mode, launch DDU, uninstall drivers, reboot system, install new drivers.
