Hello,
Long story short, I have a CM 212 EVO with a spare bracket+fan, so I attached 2nd fan to heatsink for push/pull. It worked fine, dropped 3-4 celsius, but no matter how many different attempts I tried to match the RPM of the two fans, I could not get it to work. Everything from putting the 2nd fan (pull) into CPU_OPT or Case Fan header on motherboard, and tuning RPM in BIOS, I could not get them to be simillar. Push was always 200RPM higher than pull, no matter what profiles/tuning.
Here is my question. If I buy a 4-Pin Y-Cable / Fan Splitter for two 4-pin PMW fans, would they spin at same RPM then? I'm lthinking of Noctua's NA-SYC1 model - http://noctua.at/en/na-syc1
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
https://linustechtips.com/topic/819701-question-about-fan-splitter/
2 minutes ago, M.Yurizaki said:
Short answer is yes. The PWM signal will feed into both assuming they're PWM fans.
They are both original Hyper 212 EVO fans, which are PWM. (Have so many 212 EVOs up in this place!!) xD
HWBOT
THe exhaust is pulling the intake fan.... It makes sense.....
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
As long as you use the same fans then they will recive the same signal and spin at the same RPM.
I personally use this one from rosewill and it works great.
Rosewill RCFC-16002 Case Fan Splitter: https://www.amazon.com/gp/product/B01N0XQ7XC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
| CPU Intel I7 6700K | Motherboard Asus ROG Maximus VIII Hero | RAM 16GB Corsair Vengeance LED 2666Mhz | GPU MSI GTX 1080 Ti Gaming X + NZXT Kraken g12 w/ NZXT Kraken x52 | Case NZXT h440 | Storage 500GB Samsung 960 Evo, 2TB Samsung 850 Evo | PSU EVGA Supernova G2 750W | Cooling Thermaltake Water 3.0 Ultimate |
They are exact same fans, so I'm going to press purchase!
I live in Norway, and literally noone is selling PWM splitters, only 3 headers + Molex. YUCK!
Only PWM splitter I found was the Noctua one linked in the main post, for $15 xD
Edit: Found a model from akasa for $8, named AK-CBFA04-15.
splitter för PWM-fläktar, 1x4-pin ha till 2x4-pin ho, svart Hmmmmmmmmmmmm
HWBOT
Short answer is actually no. Since there are manufacturing things to consider, even if they were to use same header, you wouldn't be getting indentical rpm. You might get closer than 200rpm, but they aren't going to be identical.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Even if it's the same fans?
HWBOT
There's always some variance. You probably get within like 20rpm. I have around 100rpm with 3pins.
