I'm going to be doing a custom loop for my CPU and wait to upgrade my GPU and get a water block for it, but I am wondering what is the safe temps for PETG since the heat gun I'm looking at only operates at 500F and 1000F
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/818673-safe-temps-for-petg/
It's not something I've looked into like that, but you can just hold the PETG further away if is too hot, you will know if it is as it will bubble
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/818673-safe-temps-for-petg/#findComment-10261979
It's not so much the heat, it's the length of time and distance from it.
Get some extra tubing and experiment at first. I would recommend making a good liberal guess on how much tubing you'll need and double it to make sure you've got plenty for mistakes :)
500F should be plenty at a few inches away from the heat source, slowly turning it of course.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/818673-safe-temps-for-petg/#findComment-10261982
Ok
Yep I'll watch videos when I'm planning out and finalizing my loop
https://linustechtips.com/topic/818673-safe-temps-for-petg/#findComment-10261992
Yup, this is the exact advice I give to new rigid tubing builders, hell ive just finished my 3rd hard line loop and still ordered 50% extra - turns out I needed it as well!
Ryzen Ram Guide
https://linustechtips.com/topic/818673-safe-temps-for-petg/#findComment-10262255
