Where are you shopping/located? Any preferred color scheme?
https://linustechtips.com/topic/81867-thin-fan/#findComment-1120032
Located in Denmark, Europe and Color scheme of the build is black and red but its not really important as it's the back fan. :-)
What shops are you using?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/81867-thin-fan/#findComment-1120106
How do I tag people? @WoodenMarker or #WoodenMarker?
Exactly what I need. :-) Thanks a lot for the help. Swedes are always so nice. :-)
https://linustechtips.com/topic/81867-thin-fan/#findComment-1120269
The first one.
https://linustechtips.com/topic/81867-thin-fan/#findComment-1120281
I think you can order from aquatuning if you cannot find them anywhere else, have a nice friday evening.
https://linustechtips.com/topic/81867-thin-fan/#findComment-1120350
