Difference between read and write
Go to solution Solved by Jarno.,
19 minutes ago, Toshi said:
I really don't get the concept!!
Somebody please clarify.
Read = User can Read the content (text file can be opened, so you can read it but you can not write (edit it)
read/write = user can open text file and type in it. write also means that you can also remove the whole file by default (exceptions can be made by using sticky bits in Linux or giving other permissions in Windows)
Execute = well you can execute it. Needs to be EXE file or any other executable (file needs executable bit in Linux)
Owner/full control = Has all the permissions above but can also grant permission to others
Overkill explanation but those where the most important permissions, :P
Think of it like a book.
You're reading words on a page, or you're writing onto the page.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
