5 minutes ago, Draconid said:
You can get laptop coolers which can help bring temps down.
They don't really tend to help....
35 minutes ago, Shrinivas Jadhav said:
Then what should i do??....and what is the avg temperature while gaming?
Make sure that no vents are covered and you might want to raise the laptop off the desk or table, I just use some wooden blocks.
Have you tried turning it off and on again?
https://linustechtips.com/topic/817719-cpu-temperature/#findComment-10253240
