PCPartPicker part list: https://uk.pcpartpicker.com/list/k4Wjr7
Price breakdown by merchant: https://uk.pcpartpicker.com/list/k4Wjr7/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£188.92 @ More Computers)
CPU Cooler: NZXT - Kraken X31 69.5 CFM Liquid CPU Cooler  (£53.98 @ YoYoTech)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  (£88.14 @ More Computers)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (£152.55 @ Amazon UK)
Storage: OCZ - TRION 150 480GB 2.5" Solid State Drive
Video Card: Palit - GeForce GTX 1080 8GB JetStream Video Card  (£519.98 @ Novatech)
Case: NZXT - S340 (Black) ATX Mid Tower Case  (£62.39 @ Aria PC)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£82.49 @ Amazon UK)
Total: £1148.45
Hi, i just changed my motherboard and my cooler today, i can't hear the pump working and my CPU right now is hovering around 80*C. HELP. I installed it according to the next website instructions, but the pump is not working
The situation is this, the cooler is securely attached to the cpu , the cables are all connected, the fan is working but the pump is not, it is destroying my CPU, please help!!!!!
https://linustechtips.com/topic/817456-x31-pump-not-working/
Just now, Rushton said:
I just bought it, it was brand new. Never used before
the name sounds old to me since theres the x61/x62 out all ready
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250377
This one came out abotu 3 year ago, but it is still in production,
See if anyone else has the problems
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250389
first thing i would check - The pumps plugged into the CPU fan header try disabling cool and quiet on it!, or alternatively try another fan header first, before assuming it's dead... if it works on another fan header make sure you disable cool and quiet for it in the bios, and plug another fan into CPU to satisfy the BIOS.
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250419
Make sure the pump is powered and not on some fan curve, make sure the radiator is above the pump block and the barbs are at the bottom to try to bleed the air to the top too, but you'd hear the pump it was running dry
Yours faithfully
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250436
i can't hear the pump at all
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250465
its cold
your pump is either broken or not receiving power.
run the fan header you plugged it into at full power.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250469
I'd say dead circuit board in the block, best return it, or confirm that the header is providing power and can power a pump (they draw more power than a fan)
Yours faithfully
https://linustechtips.com/topic/817456-x31-pump-not-working/#findComment-10250479
