Posted August 4, 2017 So Im using a buddys HP Pavillion case right now and I want a sort of lan box to take to my friends houses or something in general that is portable, so my budget is gonna be 70$ for sure maybe 100 if im lucky (Birthday Money) And I have my eye on a few cases here are the links: So My needs are a micro atx case and something that can fit a Gigabyte GTX 1060 G1 gaming and a 3.5 inch hard drive thats why im excluding mini itx cases. Overall i need something with a 5.25 inch bay 1 is fine but 2 is good and standard atx support around 100 or less, used isnt really an option, Thanks for the help!!! Core V21 https://www.newegg.com/Product/Product.aspx?Item=N82E16811133274&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+(Computer+Cases+-+ATX+Form)-_-N82E16811133274&gclid=CjwKCAjwk4vMBRAgEiwA4ftLs8P8xo9-Z0wS0WpSbTjKfjZ3MRYJSFei2Gjx--AmmqWzcSHodOO_OBoCdEQQAvD_BwE&gclsrc=aw.ds Haf XB Evo https://www.newegg.com/Product/Product.aspx?Item=N82E16811119265&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+(Computer+Cases+-+ATX+Form)-_-N82E16811119265&gclid=CjwKCAjwk4vMBRAgEiwA4ftLsxVYiKNSTdIbddTel5aFGSeQXlUD-JOviYoSl2kYvWoqZYUiN0XyBhoCBhoQAvD_BwE&gclsrc=aw.ds Corsair Carbide https://www.newegg.com/Product/Product.aspx?Item=N82E16811139045&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+(Computer+Cases+-+ATX+Form)-_-N82E16811139045&gclid=CjwKCAjwk4vMBRAgEiwA4ftLs0q1lzjBc_EcTJo2F26HJE9jOwAB_CEmQeX7IdO5Caq8tpWLsMqY3hoCzpcQAvD_BwE&gclsrc=aw.ds Antec P50 https://www.newegg.com/Product/Product.aspx?Item=N82E16811129228&cm_re=antec_p50-_-11-129-228-_-Product Slightly fishy antec P50 (I can return in 30 days if i dont like it) https://www.newegg.com/Product/Product.aspx?Item=9SIA98C62J8575&cm_re=antec_p50-_-2AM-000V-00071-_-Product Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 air 240 PSU Nerd | PC Parts Flipper | Cable Management Guru Helpful Links: PSU Tier List | Why not group reg? | Avoid the EVGA G3 Helios EVO (Main Desktop) Intel Core™ i9-10900KF | 32GB DDR4-3000 | GIGABYTE Z590 AORUS ELITE | GeForce RTX 3060 Ti | NZXT H510 | EVGA G5 650W Delta (Laptop) | Galaxy S21 Ultra | Pacific Spirit XT (Server) Full Specs Spoiler Helios EVO (Main): Intel Core™ i9-10900KF | 32GB G.Skill Ripjaws V / Team T-Force DDR4-3000 | GIGABYTE Z590 AORUS ELITE | MSI GAMING X GeForce RTX 3060 Ti 8GB GPU | NZXT H510 | EVGA G5 650W | MasterLiquid ML240L | 2x 2TB HDD | 256GB SX6000 Pro SSD | 3x Corsair SP120 RGB | Fractal Design Venturi HF-14 Pacific Spirit XT - Server Intel Core™ i7-8700K (Won at LTX, signed by Dennis) | GIGABYTE Z370 AORUS GAMING 5 | 16GB Team Vulcan DDR4-3000 | Intel UrfpsgonHD 630 | Define C TG | Corsair CX450M Delta - Laptop ASUS TUF Dash F15 - Intel Core™ i7-11370H | 16GB DDR4 | RTX 3060 | 500GB NVMe SSD | 200W Brick | 65W USB-PD Charger Intel is bringing DDR4 to the mainstream with the Intel® Core™ i5 6600K and i7 6700K processors. Learn more by clicking the link in the description below. Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247213 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author 7 hours ago, JDE said: air 240 why exactly? Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247219 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Just now, Aidanlockett1 said: why exactly? I like Corsair, also makes sleeve PSUs last long PSU Nerd | PC Parts Flipper | Cable Management Guru Helpful Links: PSU Tier List | Why not group reg? | Avoid the EVGA G3 Helios EVO (Main Desktop) Intel Core™ i9-10900KF | 32GB DDR4-3000 | GIGABYTE Z590 AORUS ELITE | GeForce RTX 3060 Ti | NZXT H510 | EVGA G5 650W Delta (Laptop) | Galaxy S21 Ultra | Pacific Spirit XT (Server) Full Specs Spoiler Helios EVO (Main): Intel Core™ i9-10900KF | 32GB G.Skill Ripjaws V / Team T-Force DDR4-3000 | GIGABYTE Z590 AORUS ELITE | MSI GAMING X GeForce RTX 3060 Ti 8GB GPU | NZXT H510 | EVGA G5 650W | MasterLiquid ML240L | 2x 2TB HDD | 256GB SX6000 Pro SSD | 3x Corsair SP120 RGB | Fractal Design Venturi HF-14 Pacific Spirit XT - Server Intel Core™ i7-8700K (Won at LTX, signed by Dennis) | GIGABYTE Z370 AORUS GAMING 5 | 16GB Team Vulcan DDR4-3000 | Intel UrfpsgonHD 630 | Define C TG | Corsair CX450M Delta - Laptop ASUS TUF Dash F15 - Intel Core™ i7-11370H | 16GB DDR4 | RTX 3060 | 500GB NVMe SSD | 200W Brick | 65W USB-PD Charger Intel is bringing DDR4 to the mainstream with the Intel® Core™ i5 6600K and i7 6700K processors. Learn more by clicking the link in the description below. Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247225 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author 7 hours ago, JDE said: I like Corsair, also makes sleeve PSUs last long yea but that has nothing to do with my case needs or anything and price is high also Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247228 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 P50 or carbide Want to custom loop? Ask me more if you are curious Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247245 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 9 minutes ago, Aidanlockett1 said: why exactly? An actual reason (not "because corsair!") Is the high airflow you will get. Want to custom loop? Ask me more if you are curious Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247249 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author 4 minutes ago, Damascus said: An actual reason (not "because corsair!") Is the high airflow you will get. yea but its inportant to me to have 1 5.25 inch bay and at this price point i dont see it fit to buy it but high airflow makes sense and it has spacious 3.5 and 2.5 bays Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247272 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Quick note, I love my inwin 301 (matx) Its got a 3.5, 2 2.5 and a tg side panel for a mere 70 bucks. (Inwin 101 is the same but with ATX) Want to custom loop? Ask me more if you are curious Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247281 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 4, 2017 Author Just now, Damascus said: Quick note, I love my inwin 301 (matx) Its got a 3.5, 2 2.5 and a tg side panel for a mere 70 bucks. (Inwin 101 is the same but with ATX) yea but its not something that i can throw around and scratch(not saying im going to abuse my case but acidents happen) and its not very portable imo and it dosent hae a 5.25 Link to comment https://linustechtips.com/topic/817144-lan-box-pc-case-roundup/#findComment-10247286 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
