Decent laptop for web browsing for around £400 - £500?
Guest
I currently have a decent PC with a 4790k, 16 GB RAM, GTX 980 and a few SSDs.
I'm looking for a cheapish laptop that can be used as a backup or just for relaxing in bed with. I just need it to do basic smooth web browsing, have a fair bit of storage and to be reliable.
I relaly can't ring myself to spend more than £500 as at that point I would just be thinking "I should really just get another PC at this point.." so if it's possible, I'd like to spend no more than £450; but I will spend up to £500 if I have to.
I currently have have a decent Sony Vaio lying in the shed that has 8 GB RAM and an i5 but I bought it back in 2011 and it's currently smashed up (don't ask how). It would probably cost more to have it repaired than it's worth and most likely has a ton of viruses, 14 year old me wasn't too net-smart back then. So I really can't be bothered buying a new HDD, reinstalling Windows and getting the screen and casing replaced.
Any help is appreciated!
Maybe upgrade the storage in a chromebook?
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
the best advice i can give you is go used.
I don't know a ton about laptops, but cex has some good deals on used laptops.
bregsit
PC specs: i7 4770s, Zotac GTX 1070 Mini, 16GB DDR3L 1600MHz (2x8GB, cheap Crucial RAM), Crucial BX500 480GB , 2x WD Blue 1TB, Seagate Barracuda 1TB, Windows 7
Laptop Specs: i5 5350U, Intel HD something, 8GB (probably DDR3 idk), 128GB Samsung(?) SSD, MacOS whatever the newest one is
Any chromebook recommendations?
Ah, I live near a CeX, I could maybe give that a go. Never been in there before.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I'd order it online. I think it's only like £2 for shipping anyway and you'll have more choice
bregsit
2 minutes ago, JDE said:
I know this sounds dumb, but how well do External Hard Drives work on Chromebooks? I've never used the OS before. If they are okay, I could just use external and cloud storage and not worry about upgrading.
Well if its just for web browsing I recommend the $329 iPad.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
Yeah, they work. IDK about how well but external works. Cloud works great though.
Full Specs
Helios EVO (Main):
Delta - Laptop
People here like to hate on Acer but this one seems pretty nice: https://www.amazon.com/Acer-Chromebook-ChromeOS-Certified-Refurbished/dp/B01K5EBCES/ref=sr_1_1?ie=UTF8&qid=1501844853&sr=8-1&keywords=chromebook+ips+screen
Also, like others have said it's probably worth taking a look at secondhand thinkpads.
Specs:
PSU: Corsair CS450M
