Hey guys I need a favor. Can someone with a 900D measure the inside of the case. These are the measurements I need: the depth (inside from the motherboard tray to the inside of the side panel.) and from front to back (inside front starting with a hard drive cage inserted from the side of it to the back of the case). It would be nice if the measurements in metric (cm OR mm). A little preface as to why I am not doing this myself in my own case. I'm overseas trying to use my fathers workshop tools and acrylic to make a midplate and I left my measurements back at home.
https://linustechtips.com/topic/814754-900-d-measurement-help/
Every case is different so if someone else measures theirs there is a fair chance your midplate won't fit into your case. Maybe search up your case online and look for the CPU cooler clearance for a reference measurement.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/814754-900-d-measurement-help/#findComment-10221572
