I have a Asus Prime H-270 Pro and i a corsair CX 550 and an Interesting I5-7600
I was really really stupid and i plugged in the legacy power/ floppy disc power into a fan controller thinking oh you do molex to fan and a fan controller is on the end, Yea i'm stupid i know i fried the mobo so i'm trying to RMA but i'm reading and i think they won't replace it so Rip my life but is my CPU fried? The GPU wasn't fried from the looks,
The reason it friend was becuase i was dumb and was gonna test my PSU but left the legacy power in I'm so dumb ik idk i was just so excited and boom shattered my dreams but is the CPU ok or do i need a new one, Also what about the ram? the controller was right next to ram/24 pin power please help thank you!
https://linustechtips.com/topic/813889-cpu-fried-pls-help/
im not quite sure what you did here to be honest
Builds:
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10212200
@Bryce2254 I doubt the CPU and RAM are fried, tbh I think the mobo itself may have survived this, maybe only this fan header is broken now. Just hook up all cables properly and try again.
Edited by wkdpaul
cleaned up
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10212298
1 hour ago, Bryce2254 said:
I plugged Legacy Power/ Floppy disk power from a PSU into a fan controller on my motherboard
ok. so. im still not 100% sure what you actiually did but im assumeing you pluged one of those small MOLEX connectors with 4 pins into a fanheader. that would most likely take down your board but i would say the CPU is probably fine but not guaranteed fine
Builds:
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10212391
What did it do, did it smoked, exploded, smelled or anything? The board should have some kind of overvoltage protection, but everything is possible. I suggest you check the board with different ram and CPU and try your RAM and CPU in other board
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10212867
It made very loud POP and smelled like burning
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10215877
If you look at a Legacy Power connector i plugged that into a fan controller/header
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10215880
Mobo was out i think, The LEDS were on but no boot/post so i just sent it back for an RMA lets hope they actually accept it :(
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10215881
tutorial-4pin_fdd_power_conn.jpg Into a fan controller
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10215888
Well at least you destroyed the fan controller and most of the motherboard. psu might have taken damage. CPU we can't say, I would guess it has a 50% chance of being alive
Builds:
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10217211
Yah that's what I was talking about. It's almost entirely the reverse of a fan header
Builds:
https://linustechtips.com/topic/813889-cpu-fried-pls-help/#findComment-10217213
