How should I do my cooling setup
Solved by MVPernula,
3 minutes ago, ItsMestro said:Thank you but I have a feeling that it's gonna be hard to get the radiator to reach the front of the case. Also do you think I should get some other fans for the case(and maybe the AIO Cooler) or just keep the stock fans? If so then which ones?
Seems fine:
I would start with the stock fans and replace them if you find them too noisy and bad later down the road!
Featured Topics
WindirBear ·
Posted in Networking0 -
5
7
3
Biffonick ·
Posted in New Builds and Planning3 -
jtrussell22 ·
Posted in Programs, Apps and Websites8 -
3
3
Wiibuntu ·
Posted in Linux, macOS and Everything Not-Windows20 -
