new x299 system won't post
Troubleshooting Help:
What is your parts list?
2x strix 1080 Ti with waterblock (I know 1 of them works 100% because I've used it in the past)
7900x delidded from caseking.de
asus prime deluxe
2x 16 GB gskill ripjaws 3200mhz 16cl
m.2 nvme ssd
corsair ax1500i
Describe your problem. List any error messages and symptoms. Be descriptive.
Oh boy. After finally completing the build I plugged the 24pin cable into the motherboard and started my PC,
all motherboard lights turn on, my monitor sais there is no signal; ASUS q code error on the LED display has a little CPU picture on it and the code is 00 which research has shown to mean it can't even get passed the first step.
As I was filling my watercooling loop I jumpered the 24pin cable and could fill my loop, have fans running all no bother.
List anything you've done in attempt to diagnose or fix the problem.
  1. A single ram stick in every configuration
  2. replaced displayport cable and replugged it into every display port on the (2) GPUs
  3. Used the reset button and turn on button on motherboard
  4. Cleared cmos.
  5. Replaced all cables used from PSU, (I know PSU works from previous build)
  6. Removed the 8x power cable to the cpu, resulting in a red light turning of indicating me to plug it in.
Post relevant photos of build/parts here.
https://imgur.com/gallery/1e8t2
Provide any additional details you wish below.
I've built a few systems before so I doubt that my incompetence is the issue, I'd be happy if it was though :P
from my research error code 00 means either the CPU or the motherboard is at fault..
I'm all out of ideas.
Thanks for reading my post.
use cpu in another motherboard if possible, id say get a return on the cpu... but delid
never build inside the case before you are 100% sure all components are working
did you get warranty for that delided CPU? was it tested after the delid process?
new to this forum so I've no idea if this is how you reply.. My new rig as seen in the images is watercooled so there is no way of cooling it outside.. I got a 2 year warranty from the delidded cpu, just not sure if I should send back the CPU or the motherboard first, eitherways one of them seem to be the issue
if it's watercooled what!? you don't make sure the components actually work before? especially when you're doing a custom loop
components can arrive DOA, it's a thing
you said you are using 2 gpu's. Are you using a 2-way sli bridge and try taking one out.
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
how do I check them if I do not have a compatible air cooler for the CPU? I wouldn't dare turning it on without it's heatsink/cooler
using a HB 2 way SLi bridge, I REALLY doubt it's got something to do with it though, especially since the CPU is the first thing it tries to initialise and it's already failing on that
Just try removing the other gpu (and the sli bridge)
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
Also, try using the onboard graphics. O that's right x299 doesn't have them. AHH intel
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
I think my best option is getting another CPU and trying it out, I'll remove the SLi bridge but removing the GPU without completely dismantling the loop is impossible :l
Ahh you have a custom loop. That's a bummer. You should always test with air before you go underwater.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
If you haven't already, recheck the CPU seating. With the CPU out, visually inspect the socket for any damage to pins.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
good idea. I didn't think of that one
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
the first motherboard I've received had 3 bent pings which felt impossible to rebend, sent it back and I can definetly tell this one has no bent pins, at least not visible
I received an asus mobo that was bent. I built a pc for a friend. Like everything still worked fine on it. Just that it had a curve in it. Check for that. unlikely though
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
the motherboard itself was bent? that sounds crazy
ikr
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
