Are these voltages normal, the yellow voltages are while the drone is in flight and the green ones are while the drone is landed
The weird kid in the corner eating glue
“People think that I must be a very strange person. This is not correct. I have the heart of a small boy. It is in a glass jar on my desk.” - Stephen King
https://linustechtips.com/topic/812091-phantom-3-battery-voltage/
question: Do you know what voltage droop is?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
yes, so this is normal?
a .2V per cell droop while under heavy load is very normal.
System specs:
okay, thank you
