hello LTT forum,
I posted last night needing some help to build a pc that could run games pretty well and can run autocad. My budget was around 700$ and I modified a parts list put together by @deXxterlab97. Would you all be able to help me by letting me know if there any changes I should make or if it is good how it is.
Thank you
PCPartPicker part list: https://pcpartpicker.com/list/t8M6tJ
Price breakdown by merchant: https://pcpartpicker.com/list/t8M6tJ/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($131.88 @ OutletPC)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($52.65 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($149.99 @ Best Buy)
Case: Xion - XON-310_BK MicroATX Mid Tower Case  ($23.98 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($37.99 @ Newegg)
Total: $708.23
Generated by PCPartPicker 2017-07-23 14:48 EDT-0400
https://linustechtips.com/topic/811580-pc-build-help-check/
1 minute ago, That_PC_Kid said:
The build looks good for 60FPS+ gaming at 1080p. The only thing is I've heard that the CXM line up of Corsair PSU's are pretty shitty. I'd suggest upgrading to an EVGA - B3 550W 80+ Bronze Certified Fully-Modular ATX Power Supply.
Define 'shitty', they both won't explode in a system that requires less than 300W, no big deal.
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186209
The new grey-label CXM is actually very decent. Tier 3 (due to sleeve bearing fan). The old CX models had a 30°C rating, the new ones are rated at 40°C
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186210
Nope the new units are good.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186218
1 minute ago, PaddyShack07 said:
Found a problem, I cant find that gpu anywhere. Anyone have recommendations for a good gpu under 200$?
980?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186219
any 1050ti
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186220
15 minutes ago, PaddyShack07 said:
If its fits in the budget yea, but if you can find a 980 for sub $180 (or $200 if the budget permits) get it
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186275
The new CXMs are excellent and if you have a ball bearing fan they would be in Tier 2.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186297
23 minutes ago, That_PC_Kid said:
@seon123 @Jrock my bad. I've just been told time and time again by the members on here that those PSU's aren't very good.
It's the old ones. They made like 10 different models with varying levels of quality.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/811580-pc-build-help-check/#findComment-10186301
