I have an monitor I want to run off my i7 intel core 2015 Macbook air, I can easily run the monitor off the integrated intel graphics but I have a desktop 1050ti gpu and a spare motherboard. Is it possible to run the GPU off the motherboard into the monitor (With a PSU of course), but run the CPU and processing off the Macbook? Please help!
https://linustechtips.com/topic/810848-egpu-set-up-help/
Why not go full PC? A G4560 costs $60 and  8gb of ddr4 around $40.  If you already have a power supply and case then the resulting PC will likely be on par or better in CPU performance to your laptop and it would have a 1050 ti
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10178974
1 minute ago, Damascus said:
A G4560 costs $60
trash xD
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10178979
Just now, Damascus said:
Run it as a hackintosh
That's really only for enthusiasts as they require constant attention.
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10178987
better than a dual core 2-3ghz i7...
Good thing I dont have one :P
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10178989
To be fair I hear gigabyte is the most apple friendly
Still far from 1hundo stable tho
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10178993
and also free.  Though I really shouldn't be talking about OS's, I just finished my first custom loop yet I'm running de-activated win10 with the little watermark in the bottom right.
https://linustechtips.com/topic/810848-egpu-set-up-help/#findComment-10179004
