Need an Electrician's help!!
Go to solution Solved by iamdarkyoshi,
Just now, RS2007GOD said:
no idea. could be but i am from New Zealand
Looks like they used the same colour code.
Red/brown is live
Black/blue is neutral
Green/greenwithyellow is ground
I have a small wiring job but im unsure how to go about it. here 2 pics of 2 different wires. the one connected is just n extention cord been cut to fit a regular light socket.
i want to use this cord
to run this light
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/808460-need-an-electricians-help/
Just now, iamdarkyoshi said:
Red to brown
Black to blue
Green to green
awesome your 100% sure on this?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
India wiring colours right?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Red/brown is live
Red/brown is live
alrighty cool will give it ago
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Got a multimeter with you? The most important one is the earth, make sure the ground pin on the plug has a connection to the metal chassis of the light
no i dont sorry. i dont usualy muck around with this stuff
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
They're pretty cheap, I'd suggest picking one up. Even a basic multimeter would do.
Green with yellow or green has always been earth, I wouldn't worry about it.
cheers guys WIN_20170717_14_43_38_Pro.thumb.jpg.44a75a6608d53bda31805db3dd7bc4c5.jpg
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
