I was wondering, are all the tripod mounts on DSLRs (and SLRs) all the same?
I behold myself a beautifull SLR (yes, not digital, shoots on colour 35mm) Pentacon Praktica L and wanted to buy myself a cheap tripod considering I'm quite new to photography (later on I plan on purchasing something a bit more expensive, but for now this will do).
I found this e-bay listing which claims it fits several Nikon models, which makes me wonder: if he mentions the nikon models does that mean my Praktica (which has a regular tripod mount) won't fit there? So I was wondering does any1 know will my Praktica fit on here considering it has a regular normal tripod mount on itself.
This is the ebay listing I was talking about: http://www.ebay.com/itm/Stativ-Tripod-TA30-125cm-SCHWARZ-BLACK-f-Nikon-D3200-D3100-D5200-D5100-D40-/191892064111?hash=item2cada8876f:g:V3YAAOSwhQhY14E1#shpCntId
Yours sincierly,
Domagoj Rupnik
Domagoj Riddle Rupnik, prof. mag. chem.
https://linustechtips.com/topic/807672-help-tripod-mounts/
yes, they are all the same. The title is probably just to gain attention. The only thing I'm wondering is for what that extra pin on the mounting plate is.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/807672-help-tripod-mounts/#findComment-10144823
Some cameras have a extra hole in the bottom to keep them from rotating
https://linustechtips.com/topic/807672-help-tripod-mounts/#findComment-10144825
Just to elaborate further, while on cameras the quick release plate mounting screw threads should all be the same size, quick release systems are not all the same.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
https://linustechtips.com/topic/807672-help-tripod-mounts/#findComment-10144833
I recommend not getting that cheap one. If you dont have more money right now, just wait until you have. Those cheap tripods will just break easily, and will sway with just little bot of weak wind.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/807672-help-tripod-mounts/#findComment-10144946
That thing would wobble like crazy with a kodak one use camera you could get from a kiosk in the 1990s, an older slr... just handhold it instead!
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
https://linustechtips.com/topic/807672-help-tripod-mounts/#findComment-10145302
