Good Fan HUBs?
Solved by WoodenMarker,
1 minute ago, iLoveLogitech said:Is there a cheaper option? $24 seems a bit.. expensive. If there isn't I will consider it, as I have to anyways, it's decently hot here in Vancouver
I'm not sure if you overlooked it but I gave two recommendations.
The Phobya Y-Kabel is $14.
BoBo6107 ·
R_public ·
Posted in Networking11 -
apoyusiken ·
Posted in PC Gaming0 -
4
MattJames595 ·
Posted in Troubleshooting0 -
Jimkirk363 ·
Posted in Windows4 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory7 -
asdasdasdasdasdasd ·
Posted in Hot Deals1
