Okay one question I have about sli is, how do the cards get into sli. Do they have to be exact same cards? Or say can it be a msi gtx 980 ti and work sli with an evga 980 ti hybrid?
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/803993-how-does-sli-work/
As long as it is the same GPU you can SLI or Crossfire them, so yeah you can use those two cards.
An example would be that you can use a RX 480 and RX 580 since they're the same GPUs
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/803993-how-does-sli-work/#findComment-10105660
It needs the same videochip, doesn't have to be the same cooler/brand and it needs to have the same amount of VRAM IIRC (so yes, you can mix the EVGA and MSI 980 Ti, because they are both 980 Ti's with 6GB VRAM).
https://linustechtips.com/topic/803993-how-does-sli-work/#findComment-10105664
SLI = same VRAM capacity and GPU model (so 980ti goes with 980ti, 1080 goes with 1080)
It's better to put the 980ti hybrid in the top slot since it uses an AIO for primary cooling and doesn't get affected much by another card in front of it, The same can't be said with the MSI Gaming card.
Desktop benching:
https://linustechtips.com/topic/803993-how-does-sli-work/#findComment-10105749
