I've been using my pc for around 2 years without issue. Now it is suddenly running extremely hot. Even just sitting at the desktop has it running at 85-90C.
Cpu is a 5820k overclocked to 4.5ghz at 1.275volts. I tried removing my OC just to see if there was any difference, but even at 3.3ghz stock voltage its still hitting 90C
Im using a corsair all in one cooler 280rad, and pc is dusted regularly. Could this be caused by a pump failure or something? My software monitoring shows fans and pump as operating normally.
Any ideas are appreciated.
https://linustechtips.com/topic/803715-cpu-overheating/
Put a screwdriver/pencil against the pumps, and place it next to your ear. You should feel/hear the pump if it's working.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/803715-cpu-overheating/#findComment-10102713
what @Zando Bob said,also is the rad warm to the touch?
might be worth a try to remount the cooler
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/803715-cpu-overheating/#findComment-10102767
