CPU: Fx 8350 | CPU Cooler:  probably an h100i  | Motherboard:  MSI 990FXA-GD80 Ram: Corsair Vengence 8GB DDR3 | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung  Case : still thinking. '
How much W is needed for the above specs?
Thinking to buy a sea-sonic psu please let me know the best wattage I do not want to fall short if my gpu dies on me and I want to buy a new one I do not want the psu to not support it and buy a new psu again.
PS- MY pc died in 2013 im building it again same parts just need to buy a new case and psu and a cpu cooler :)
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/803531-how-much-w-is-required/
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/803531-how-much-w-is-required/#findComment-10100835
56 minutes ago, JDE said:
1 hour ago, RKRiley said:
if only these models were available here ;-;
https://linustechtips.com/topic/803531-how-much-w-is-required/#findComment-10101163
Just now, RKRiley said:
Where are you buying from.
India. the only brand I can find right now is cooler master and the last power supply I had was cooler master thunder it sucked.
https://linustechtips.com/topic/803531-how-much-w-is-required/#findComment-10101178
Don't buy by brand. Some Cooler Master PSUs are VERY good and high quality.
Anyways:
THIS UNIT IS AVAILABLE WHERE YOU LIVE:
https://in.pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
It's about 10000 rupees, and if you have 20000, this unit is much better, but overkill:
https://in.pcpartpicker.com/product/qNrG3C/cooler-master-power-supply-rs850afbag1us
(This cooler master is Tier 1, very good power supply)
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/803531-how-much-w-is-required/#findComment-10101435
https://linustechtips.com/topic/803531-how-much-w-is-required/#findComment-10102364
