so i recently bought a sapphire 6970 flex edition i was hoping i would get temps like 70 to 75 at max load but in this case i'm getting more i'm getting 84 degrees at high on bf4. 1080p is this normal for 6970 cards?
Yeah, that's normal for most GPUs. It's even normal for the Radeon R9-290X to run at 95 degrees C.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1101541
I like my Radeon HD 6570 with the IceQ cooler. Never goes above 41C, EVER. But performance... Yikes.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1101611
ah. thank you very much! :D  thought my gpu fan was broken or something
Trust me, you would know if it wasn't working. ;) And welcome to the forums, almost forgot to mention that, silly me.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1101615
If you can, get software like MSi Afterburner and make your own custom fan profile. That way, you can adjust your fan RPM to be higher or lower at certain temperatures or at whatever points you feel more tolerable. For reference, my R6950 regularly hits 50C while folding / gaming and tops out at 60C while benchmarking, with a custom profile. On the stock profile, it hits 75C + no problem (albeit on a reference cooler)
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1101655
hey now dont max out your fans or they will not last as long, once them fans die your cooling ability will be reduced a lot.
Listen if you care.
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1104140
Even my 460s dont get that. 70-74c. And this is with single fan coolers.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/80348-radeon-6970-too-hot/#findComment-1104227
