Hi everyone,
I am building an Ethereum mining rig, and I was wondering which option would be the better choice. I am stuck between either 2x Rx 580 4GB GDDR5, or 1x Rx580 8GB GDDR5. I think the 8GB one would last longer, considering that mining Ethereum is getting harder and harder, but the hash rate of 2 4GB ones would be higher. Also, what are some good motherboards and cpus for this, since I'm on a tight budget.
Thanks,
hellochicken
https://linustechtips.com/topic/803216-ethereum-mining-cards/
With the insane prices RX cards are going for, it'll be really hard to get a good ROI before the market crashes. Now isn't a good time to get into mining, and I'd wait till Vega if you want to do it no matter what. Or just use the card(s) you have already and see if you can make some cash from mining with those.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097500
I think you're late to the party...
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097509
Dude, too little to late. Ethereum should soon start getting harder and harder to mine pretty soon. Jumping in now probably isn't a good idea, but you asked so I will answer to the best of my ability.
When mining, CPU and motherboard do diddily squat. You will only care about your PSU and GPU(s). Find a motherboard with as many PCIEx16 slots as can be crammed on to the board and hook up a bunch of GPUs with risers since you can't fit 4+ GPUs on any normal motherboard. You'll almost certainly have to build your own case for this. No one really knows when (or if) Ethereum will crash, but my guess would be within the next 1 to 9 months. See, I have no idea and I haven't come across anyone that does know.
CPU: i7 4790k @ 4.7 GHz
GPU: XFX GTS RX580 4GB
Cooling: Corsair h100i
Mobo: Asus z97-A
RAM: 4x8 GB 1600 MHz Corsair Vengence
PSU: Corsair HX850
Case: NZXT S340 Elite Tempered glass edition
Display: LG 29UM68-P
Keyboard: Roccat Ryos MK FX RGB
Mouse: Logitech g900 Chaos Spectrum
Headphones: Sennheiser HD6XX
OS: Windows 10 Home
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097542
6 minutes ago, hellochicken said:
I was wondering what would happen when Ethereum crashes, and around when it would be. Also, what are some good specs for a mining rig.
high hash rate, low tdp
get a 1200W platinum or titanium PSU with a board that has 6 or more PCI-E expansions with 16GB RAM, all the GPUs you can fit with splitters and raisers, and cheapest everything else
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097549
Alright then, it doesn't seem like a good idea to invest in ethereum. But what would be a better cryptocurrency to invest in right now? I was thinking of zcash.
I'd advise just spending the money on upgrading your current rig. You can use it for mining when you're not gaming, so you don't have to worry about trying to pay off the cards. Investing in cryptocurrency is like being a successful stock market trader. You have to keep track of your costs, current ETH to USD ratios, whether they'll go up or down, how it'll fluctuate, blah blah blah. Just get a sweet gaming rig, and it should run mining programs no prob.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097596
That sounds like a good idea, but I have an i5-7500. Apparently it has a max number of 16 PCIe lanes. Would I be able to add another graphics card to my gaming build?
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097606
What's your current rig?
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097611
15 hours ago, hellochicken said:
I currently have an i5-7500, a Asus ROG b250f gaming, a MSI GTX 1060 Gaming x 6GB GDDR5, and a 650W PSU.
You should be able to make some money just mining with a single 1060. I'd wait until the mining craze is over, then get a Ryzen 5 1600, B350 board, 16GB RAM, and a 1070 or two. Then next time a profitable currency comes along, you'll have two cards that are awesome for gaming and decent at mining. Or get two Vega cards when they come out.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097635
2 minutes ago, Zando Bob said:
You should be able to make some money just mining with a single 1060. I'd wait until the mining craze is over, then get a Ryzen 5 1600, B350 board, 16GB RAM, and a 1070 or two. Then next time a profitable currency comes along, you'll have two cards that are awesome for gaming and decent at mining. Or get two Vega card when they come out.
I am running it currently, and getting about 18.5-19 mH/s. Is there anyway to boost this? I read somewhere that I can boost the memory clock speed using MSI afterburner? Would you recommend this?
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097649
If you do it right, it should be fine. I think VRAM speed is a big factor in mining. If you can find a decently priced 1060, you could run two for more profits, though they don't support SLI for gaming.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097659
Ok, thanks for the replies. If I were to add another one though, could my build support it, since I only have 16 PCIe lanes on my i5-7500, and only 20 PCIe 3.0 lanes on my motherboard?
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097671
Yes. It says it supports Crossfire (AMD's version of SLI), so it can take two cards.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097682
Keep in mind that Ethereum is in active development with a planned stepped transition to proof-of-stake later in the year, which will phase out the mining. So an 8 GB card may last longer but it could be just a few or several months anyway.
Mining for many of the other cryptocurrencies does not require high memory bandwidth and/or large VRAM.
The PCIe bandwidth shouldn't matter much. With some it's the GPU working with its own data in VRAM that counts; you're not talking about huge data transfers between the CPU and GPU.
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097684
Would one of them be bottlenecked, since it only has 20 PCIe 3.0 lanes? And would my processor, the i5-7500, work with both, since it says that it has 16 PCIe lanes maximum here: https://ark.intel.com/products/97123/Intel-Core-i5-7500-Processor-6M-Cache-up-to-3_80-GHz
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097695
I wouldn't think so. It'd probs take bandwidth from your main PCIe 3.0 x16 slot, making them both x8. Should be fine, since there aren't any GPUs that can saturate a whole PCIe x8 slot AFAIK, and a 1060 defo won't.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097715
I wouldn't think so. It'd probs take bandwidth from your main PCIe 3.0 x16 lost, making them both x8. Should be fine, since there aren't any GPUs that can saturate a whole PCIe x8 slot AFAIK, and a 1060 defo won't.
And the processor?
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097722
1 minute ago, hellochicken said:
And the processor?
I doubt it'll be the bottleneck, though with $700 to spend, you could easily get a new mobo and Ryzen or an i7.
Mouse: EVGA X17
https://linustechtips.com/topic/803216-ethereum-mining-cards/#findComment-10097731
