HELP! Windows 9.x - XP not installing HELP!
Windows 9.x to XP on my 2011 eMachines EL1358 is not installing. I've tried ISO's they didn't work I tried downloading the files. That didn't work. So I'm stuck with Vista and up. I can't put it in a VM as EVERY time I try to boot one it locks up my system.
Edited by NotLinus101
https://linustechtips.com/topic/802473-help-windows-9x-xp-not-installing-help/
1 hour ago, NotLinus101 said:
I am currently just copying an ISO of XP to it
9x through to XP won't boot from a USB (though as I recall you can get 2K and XP to with some fiddledicking around). But no matter how you look at it, 9x is too old for this hardware (as is 2000 honestly), and while XP would install you'd still need to scrounge up a disk for it or figure out how to get it to boot from USB and hope that you can find the drivers.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
