quite simply windows yesterday without asking or warning me updated and I have had two major bugs since then and one outstanding one from before the update
1- 7 days to die couldn't connect to steam (I believe it was OS based as it could and did right up to the update (I was playing it when windows decided to give me the middle finger and update without warning again) and could again after restarting (small bug but yea
2- well this
https://gyazo.com/6575b5ee784f4e98a60533e629791153
I can not turn my PC off without pressing the power button, and if I do CTL+ALt+Delete I get an error message there as well (can't capture an image of this I don't think)
Outstanding bug
when I put my PC to sleep it randomly turns back on, WOL is not on etc. and keyboard mouse etc. aren't touched, this was fine before I reinstalled windows (cause many reasons) as it would turn on for 2-5s then turn off but since doing the reinstall it will turn on indefinitely, which is an issue as I normally put it to sleep so I don't lose important data, etc. but this turning it's self back on has caused that as windows has updated several times during this window when I'm asleep (no the latest update wasn't one it happened while I was playing 7 days to die and did it without warning while I was at the PC)
Are these bugs just me or is windows 10 just a piece of shit I need to use, as I can't afford 7 and I can't use linux as I can not be bothered setting up all the emulators needed for me to play my 100+ games and use programmes
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/801916-are-these-problems-just-me/
Hi,
To help resolve your concern regarding sleep/power off issues, try out these steps:
  1. On the Start menu, type Troubleshooting and hit Enter.
  2. On the left pane, choose View all.
  3. Choose and run the Power troubleshooter
if the problem is still there when you tried the power troubleshooter, try the following steps:
  1. Press Windows key + X on your keyboard.
  2. Choose Command Prompt (Admin).
  3. Type or copy this command and hit Enter.
     powercfg –restoredefaultschemes
  4. Exit Command Prompt.
  5. Restart your computer to apply the changes.
hope this helped.
Current Build:
CPU: Intel Core i7-7700K at 4.8Ghz CPU Cooler: NZXT Kraken X62 AIO Motherboard: gigabyte Z270X ultra gaming
Memory: Trident Z rgb 16gb 3000Mhz
Storage: Samsung 250GB SSD Storage2: sandisk ultra II 960gb SSD Video Card: Asus GeForce GTX 1080 O8G STRIX
Case: Phanteks ECLIPSE P400
Power Supply: Corsair RM650X Fans: 2x 120mm NZXT Aer rgb LEDcontroller: NZXT Hue+ LEDstrip: cablemod hybrid-LED/UV 60Cm
peripherals:
Keyboard: Razer Blackwidow X Chroma Gamepad: Razer Tartarus Mouse: Razer Mamba TE 2015 Chroma Headphones: Logitech G533 Wireless
Operating System: Microsoft Windows 10 Pro OEM Monitor1: AOC Q2577PWQ 2560X1440 OC'ed to 75 Hz Monitor2: LG 25UM57-P 25.0" 2560x1080 OC'ed to 75Hz
PCpartpicker list: https://pcpartpicker.com/list/Qt76xY
My laptop: https://www.amazon.com/Acer-VN7-571G-50VG-Notebook-Computer-i5-5200U/dp/B01CL50JV6
Quote:
If you really want it, go get it.
2 minutes ago, TommyW2061 said:
Hi,
hope this helped.
aye I will look into them thanks
oh I one other thing can microsoft please fix the fucking programme search bar thing as it just does not work, when I look for DXdiag for example, when you type in DXd it suggests a PAS file called dxdiag, when you type in DXdi(a) it suggests searching the web for Dxdiag, why the fuck do I want to google dxdiag instead of just using the fucking programme if I was going to google it I would open chrome and google it, it's only when you type in the entire name does it actually show the programme, it's even worse for Pelles C IDE (which is my C compiler) if you type in P, Pe, Pel, Pell, Pellle, Pelles it suggests the programme, but the moment you type in pelles C it suggests googling the programme, I don't want to fucking google it. (yes that isn't a massive problem to a point, but it can be as it am for ever quickly typing in pelles C and having it suggest googling it.
God I hate win 10 at times
You can disable Cortana web searches altogether like I did. Look up how to do it if you want to.
i5 6600k and GTX 1070 but I play 1600-900. 1440p BABY!
Still, don't put too much faith in my buying decisions. xD
That sounds like a good idea, can you uninstall cortana by the way, as I diny use her as she's useless (I'm scottish if you don't know what I mean by that watch these two videos
or
Those were hilarious although ironically I didn't get everything they said xD
But anyway, I don't know if you can uninstall it, but it's not a big program and once its disabled it's gone.
seriously those accents aren't even strong. And aye will do
I have difficulty with Middle Eastern and thick Scottish accents in particular xD
I can see that :P
