High Temps?
Solved by For Science!,
1 minute ago, SideWaysET said:
Looks great! Hopefully your i7 has good TIM application because I had to delid mine to get good thermals.
If you don't mind, when there is a time for it, can I re-use your first image as an "example for things that can go wrong"? since there are quite a few things that need to be spotted in one image, and nicely illustrate some of the lesser obvious things that can go wrong. Only if you are willing, of course!
